yankee-flyer
For those with a flying airplane, I found an easy way to drill all the new holes for the gear SB without removing or risking damage to damage the tank. There's plenty of room to slide a piece of .040 aluminum between the side of the fuselage and the tank-- make sure it goes all the way to the floor. Then I put a drill stop on the #30 drill and had no problems. In most cases the bit never touched the sheet and when it did the sheet moved back so the bit never even started to penetrated that, much less the tank.
Wayne 120241
Wayne 120241
