I have a RV-10 Matco 511.25 Nose Wheel with new bearings for replacement of Van's Nose Wheel. I will swap for return credit amount of Van's original nose wheel, bearings and axle or the amount of the credit from deletion from the finish kit. You would have to buy the Matco Axle for $59.28. See axel specs at:
http://www.matcomfg.com/AXLEASSEMBLY...dv-3657-1.html
It makes for a much better wheel axle assembly than Van's.
See the write up at:
http://www.myrv10.com/N104CD/upgrade...326/index.html
