HIIFLY
I built this for aFriend who was having trouble backing his RV-7 into his Hanger .
When you push down with the handle it lifts the wheel up off the ground and now steers with the Caddy Wheels . Very Easy to use and steer because the caddy wheels are in trail !
I built it out of electrical conduit , welded together and cheep wheels . It grabs the axle on the frt. Wheel same as any tow bar .
I did not invent this , I coppied and modified it .
If you can weld you can build one too .
I am just showing what else is out there .
