If you really do have the cleveland wheel, then keep it. It is a way better wheel than the Matco will ever be. Cost of that cleveland wheel is about 400 dollars. It experiences non of the problems that the Matco experiences. Rolling friction isn't an issue with the cleveland wheel. It also has a solid axle that goes clear through the wheel. You don't need to torque the bearings down to the point the wheel will no longer spin
It was pretty stiff and would not rotate so I gently filed the collars to reduce the bearing pre-load and it now spins quite freely. .
I had a heck of a time greasing those bearings (using the traditional glob-in-hand method) with the rubber seal, since they're not open on the outer side; I don't believe the cup-style packers would work on these either?
