Nose Wheel Axle Washer
Av8torTom
Hello Folks,
Can anyone tell me what the 062 25783054 washer is on the nose wheel axle? Dimensions?
Tom
Vans says it is an AN6 (3/8) hardened washer (grade 8) with an OD of 0.8 inch and a thickness of 1/16 inch
WASHER 062 25783054 AN6 0.8" Hardened
Should be at your local ACE in the aviation department...:)
Tom,
That washer is an anodized washer. I am at work now, and do not have my materials, but I believe it is listed on page four of your inventory sheet. It should fall under the header of Rv 9 nosewheel hardware. I think it may be in bag 1989. Interesting you posted, as I just installed those washers tonight.
Tom, I'm sorry. I guess my memory isn't so good after all. I checked my sheets when I got home. You should find those washers in bag 933 along with other assorted hardware.
Greg Richardson
RV9A Finish
