I am fitting the nose gear leg U-603-3 to the engine mount. I note that the end of the leg is not tapered and I can pass the gear leg through its socket and the lower collar and entire leg can pass through the mount. Is this the correct fit ? I do not note any significant play in the assembly.
My Concern is due to reports of failure of the AN5-20A bolt on VAF and the potential for the gear leg to shove up through the firewall.
This nose gear, I used a micrometer on the end of the gear leg and note no taper (1.248 top and bottom of butt end) I have already drilled the engine mount to the firewall. I do not detect any significan play in the gear leg when seated in the socket.
I need some reassurance or hand holding.
