nose gear tire/tube size
roadrunner20
Can someone get me the tube/tire size for the nose gear tire. Mine went flat on taxi yesterday.
I need to pick one up but I'm not at my hangar to get the size.
Van's web site doesn't have the desc on their parts list.
Van's pn U LAMB INNER
Thanks.
Dan- The tire size I have for my -6A is: 11x4.00-5, 6 ply rating. It is a Cheng shin brand tire as supplied in the finish kit. "Not for highway use" is also molded into the sidewall, as if you might use it there...... Not sure if the -7A is the same size or not. Good luck!
Hot off the sidewall
Aero Classic 11x4.00-5 8 Ply Rating Load Range D 94PSI Max
Desser has good deals and service, too.
John
