akarmy
![2113955340_583c961885_o.png](/proxy.php?image=http%3A%2F%2Ffarm3.static.flickr.com%2F2388%2F2113955340_583c961885_o.png&hash=cbfdf8cf61fd1de185546ef1aac83ad5)
Ok, here is how the upgrade went for me. I was lucky and had a friend that was driving down to Portland to take our gear legs and get them shortened. With this opportunity I jumped on it and pulled the leg. It was easy to remove the leg by simply jacking the plane to get the nose off the ground. I used some blocks and a tiedown strap to lift the nose off the ground.
![2113180929_1b341b67a3_m.jpg](/proxy.php?image=http%3A%2F%2Ffarm3.static.flickr.com%2F2030%2F2113180929_1b341b67a3_m.jpg&hash=7cef760f263e069bc928eca3280cf99a)
![2113960674_614e14c66b.jpg](/proxy.php?image=http%3A%2F%2Ffarm3.static.flickr.com%2F2117%2F2113960674_614e14c66b.jpg&hash=6ac068146700166e0ceac5a85352f80c)
![2113960740_4646496c19.jpg](/proxy.php?image=http%3A%2F%2Ffarm3.static.flickr.com%2F2233%2F2113960740_4646496c19.jpg&hash=76995fa11f27b0af11c136938559b402)
The main challenge in this project was getting the parts from Van's. The new nose fork took about a month to arrive. It fit perfectly and the upgrade overall was an easy task. Not sure if it's necessary, but it seems like it will help if I ever get into a hole with the nose gear. Of course it flys just the same and you can't tell any difference after the upgrade.
![2113960830_8579e644df.jpg](/proxy.php?image=http%3A%2F%2Ffarm3.static.flickr.com%2F2259%2F2113960830_8579e644df.jpg&hash=7d96367217c6543a509f526d9206bb29)
