dick seiders
I am not inclined to drill a hole thru the nose gear leg to secure the fairing to it with the #8 screw. I don't like to put holes in such places. I believe I can secure the fairing to the leg as was called for on my 6A (breezeclamp at base of fairing). Probably not necessary to secure top of fairing as hinge will stiffen and hold it in position. If necessary however, (ie; it is easily moveable) I may also use a pc of velchro on the leg at top of fairing. Has anyone else out there dealt with alternatives to the "hole"? If so would appreciate any feedback on your thoughts or methodology used.
Thanks.
Dick Seiders 120093
Thanks.
Dick Seiders 120093
