OPINION - -
The nose of the RV-12 is fairly light weight. I think that will make the nose leg far less of an issue as compared to heavier models. If it gets dropped into a deep fox hole, as example, I'm sure it will be an issue, as would any tricycle gear. I have landed on turf fairly often, and I worry less about it. Still need to avoid holes, and hold it off as long as you can.
John Bender
370.1 hours
