CharlieWaffles
For the nose fork, there is a MS15001-1 grease fitting on the front of the fork and two hex set screws on top. The top screws I see as being used to act as a stop for the turning action. The grease fitting purpose is obvious. I assume none of these need any specific torque, but are they semi-permanent and if so, would a lock-tite be a good thing here?
