dhmoose
It might just be a late night brain fade, but I want to make sure I'm stacking the belville washers correctly (page 46-06) on the nose fork assembly. These cupped washers are designed to be stacked in the same direction or in opposing directions depending on what the engineer is trying to achieve. The manual simply says "to function properly, the outside perimeter of the washers must be in contact with each other". Does this mean that the washers are stacked in opposite directions (in other words, like stacking two cups with the openings facing each other)?
Again, it may just be late and I'm tired...so excuse the brain fade.
