Dave Taylor
On RV-7 plans dwg 10A detail A (outboard stiffener) the plans call out to rivet the stiffener in assembly with the W-712 rib. I noticed the rivet just below and to the right of these 4 rivets call for a 426AD4-7 (flush rivet). Although it isn't stated in the plans and after a lot of web searching it appears that the 4 vertical rivets to the right of the 4 vertical outboard rivets should be riveted in assembly with W-414L (aileron hinge bracket assembly). I was a bit confused since I didn't see this note in the plans. Is this omission something you see a lot of or a rare instance? Or maybe I missed it somewhere. I almost countersunk the stiffener since it called out for the AN426 flush rivet. Thank goodness for the websites that have pictures.
