Hello all flyers
Did sommeone know how the nordlock washers work?
A frend told my there is a mistake by sensenich because there is an free rotaiting inlet bushing. If the bushing rotate, the hole pack will rotate incloude the nut and washer, then the screw will lose. You have to make a washerplate under the nordlock to connect two bolts.
Daniel, Switzerland
If you found typing fools, keep it![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Daniel, Switzerland
