I have a non sensitive altimeter I plan to use (daytime VFR only). The unit specifically states "no connection required" and "do not hook to static system as unit is not sealed, and will create static system leak" If I install a transponder and encoder will I be legal in class C? Should I exchange this altimeter for a better one? Thanks in advance!
