I'm building an RV-14A. Van's supplied a harness in the wings and also supplied (optional) the Aeroled Nav./Strobe. In their harness they used non-sheiled cable, so I ripped it out and installed 3 conductor shielded wire. Van's also supplied a noise filter to be mounted at the root of the left wing. Since I have eliminated the root plug and am using shielded cable I would like to install the filter at the location behind the panel where the three strobe wires (three strobes) join.
Any help in how I should add the filter or do I need one where I'm using shielded cable as per Aeroled. Aeroled shows no filter in their guide.
Thanks Ron
Thanks Ron
