No volume on comm radio
hufise
Member
Hello
I have Dynon 180 harness with skyvew options.
I put the audiolevel on ipad music to 50 to 60 % for nice sound
If you put the level to 5 to 10 % that is my full level in the com radio you can hear something but ...
In the menu if i put the Headphone Level to 255 no changes
And i had to change pin 1 and 3 for PTT pilot and copilot radio out is ok
Any other things to do
Daniel
Switzerland
In page 2 step 12 is writen remove the cable, but i got the radio with the skyvew
In page 15 is writen isolate the jacks i have donne these, but i had ad a bridge to the shield
The problem locks like speaker ground missin, but the sl-40 has no separate ground
Daniel
garmin sl-40
read the garmin manual- all of the features including the volume are internally adjustable
Yes if you put the level to 255, the volume is the same if you will lower on the knob.
The sound is all like 2 miles away
Daniel
SW ver 2.2
Rf level 070
Noise level 009
Hdphon level 250
Mic1 sqlch 41
Mic2 sqlch 61
Transmit mic1+2
Intcom lvl 100
Sidton lvl 111
Lo displ .......
On the av-50000 com1 to full
Tryed pin 13 on sl-40 to GND
I think i try pin 6 insted of pin 14 to get the speaker power as signal
Daniel
