Wyo1971,
Does the master contactor energize (click) when you turn on the master switch? If not, measure the voltage from the POSITIVE terminal of the battery to the small white/orange wire that connects to the master contactor. It should be 12 volts with the master switch turned on. If there is not 12 volts, suspect a bad ground connection or bad master switch, or broken white/orange wire connection.
Is the battery ground wire connected to a non-painted point on the airframe?
Is there power at the accessory outlet between the seats?
Joe
Wyo1971,
Joe
measure the voltage directly across your battery terminals. Then connect the multi-meter ground wire to a screw or bolt somewhere on the airframe and the Positive to the battery positive. If you get nearly the same voltage your ground is good.
Yes, the accessory outlet is always powered through an inline fuse connected to the battery. A test light is better doing some tests because it has lower resistance and puts a load on the circuit.Hey Joe, is the accessory outlet powered with the master switch off?
I would think that using a test light would give a better indication of a bad ground.
What are you using for a voltage reference, positive or negative? I had suggested using the positive terminal of the battery for a reference. If you are using ground as a reference point, then there should NOT be 12 volts on the white/orange wire with the master switch turned on. The problem seems to be at the control board, either a bad master switch or a bad connection between ground and the master switch, or between the master switch and the white/orange wire. Make sure the control board is well grounded. Then remove the firewall-forward D-Sub connector from the control board. Turn on the master switch. Then measure the voltage between the POSITIVE battery post and pin 22 on the back of the control board (not the other half of the D-Sub that goes to the engine). As Harold suggested, a test light will be better for this test because it puts a load on the circuit. The test light should be on when the master switch is on. If not, then I would send the control board back to Van's. If the test light comes on with the master switch, then the problem is in the white/orange wire or the pin that connects to the control board.The voltage is 12 volts at the white/orange wire with or without the master switch turned on.
Joe
Yes, the RV-12 uses a conventional master contactor. But according to the voltage measurements he has taken, the small solenoid terminal is not being grounded when the master switch is turned on. And that master switch is not readily accessible for testing, being buried in the control board.If the 12 uses a conventional master relay like other aircraft (i.e. you ground the small solenoid terminal to energize the coil) then . . .
Doyle,
You are welcome.
If I understand correctly, when the master switch is on, there is no voltage between the battery positive terminal and pin 22 of the firewall forward connector on the back of the control board. If this is true, then the problem is in the control board, either the master switch or a broken circuit board trace. It will not be necessary to repeat this voltage measurement with a test light unless you do not trust your volt meter.
Just to verify that the problem is not in the aircraft wiring, try grounding pin 22 on the end of the white/orange wire in the firewall-forward-wire-harness-D-Sub connector to see if the master contactor energizes.
Joe
Doyle,
It would be interesting to know if the diode caused the control board failure. Even if the diode was installed correctly, the supplier could have put that red band on the wrong end of the diode. A diode conducts electricity in one direction but blocks it from flowing in the opposite direction. The diode can be tested by removing it from the contactor and connecting the diode in series with a test light. The light should come on when the banded end of the diode is connected to negative and should not come on when the banded end is connected to positive. The new diode could be tested to be sure that it is marked correctly. This EAA Hints for Homebuilders movie explains how to test a diode.
Joe
http://www.eaavideo.org/video.aspx?v=63382258001
Doyle,
I think the diode is good and did not cause the control board to fail. If the diode was shorted out, then there would have been sparks and smoke when you grounded the end of the white / yellow wire to energize the master contactor. So the diode is not shorted out. And it is not open either, judging by your ohmmeter readings. The only number that is out of the ball park is 552. Did you make a typo or misread the meter? I would expect a number between 0.5 and 1. Another test you can do is to leave the diode connected to the small terminal and connect the banded end of the diode to ground. The contactor should energize. However it is dangerous working around the positive battery lead. Making a mistake and shorting out the battery can cause bad burns. The best way to test the diode is with a 12-volt test light.
Joe
When the new diode arrives, you could check it to be sure that the red band is on the correct end of the diode. It most likely is. But I know that you do not want to take a chance on having to wait a week or two for another control board.Anything I can check prior to the new parts arriving?
Ok, I figured it out. 552 is millivolts, not volts. Someplace on the meter readout in fine print is the units: mv. So the actual voltage drop across your diode is 0.552 volts which is good. You can double check the units to be sure.
Joe
This thread is almost a year old. Perhaps Doyle will tell us how the new control board is working and if that solved the problem.
Joe Gores
