R-1 from EI all the way!!
210 Degree Arc: The R-1 displays RPM in a 210 Degree graphical LED arc for immediate reference. Red and Yellow LED's highlight cautionary and restricted operating ranges.
Tach Time: The R-1 keeps track of Tach Time on your engine, to .1 hours.
Flight Timer: Flight Time is recorded from takeoff to landing.
Peak RPM: For every flight, Peak RPM is stored. Simply press the "Pk" button to see the previous flight's Peak RPM.
Mag Drop: The drop in RPM when switching from "Both" mags to "Left" or "Right" on your ignition switch is displayed on the large, crisp LCD of the R-1. For instance, if the drop is 110, the R-1 will display "-110."
Mag Failure Alert: If a mag fails during your flight, the R-1 will alert you by intermittently cycling through the LED's several times as you make your approach to land. Several pilots have mentioned to our support staff that this "cycling" has caught a failed mag while in flight.
Special prices for vansairforce.com members!
