Given:
Problem:
Question:
I did a search of the archives but did not find anything along these lines.
Best regards,
Michael
- 2nd hand kit (-10)
- Vic strongly encouraged us to start on the HS. This is what we are doing.
- We have no major experience using our hands and NO construction experience.
Problem:
We final drilled the skin to the spar/rib assembly and that went well enough. The rear spar was then removed from the assembly because clecos on the final 4 holes were within the structure and had to be removed (this included removing most clecos between the front and rear spar). In reassembling the HS, the holes do not appear to completely align, being fractionally off in most cases.
We expected to be able to reassemble the components and be able to pass a #40 drill through each hole without much difficulty. This is not the case.
Question:
Do we have to somehow finesse the reassembly to make this possible? If so, can you suggest how?
Best regards,
Michael
