Flying C
Member
I think I just make my first big mistake while riveting together the HS front spar. I was riveting HS-702 to HS-710 and HS-714 and while doing so got a bit carried away and riveted through two of the hole that attached HS-405 to the front spar. No big deal I thought, I will just drill out the rivets. Well I screwed up with drilling out one of the rivets and I am not sure if I need to order a replacement for HS-702 and HS-714. I have attached a photo showing the mess I made. So, where do I go from here, is there something I can do to salvage the mistake or do I need to order the replacement parts.
Jake
http://www.flickr.com/photos/13654386@N03/2502797454/
Jake
