Rainier Lamers
We will be showing off our new XTreme EFIS system at Oshkosh this year so if you are interested in a very affordable solution, give us a visit !
This unit can act as a PFD (as shown on the image), engine monitor (with external RDAC like our big EFIS systems) and it even has a built in 65 channel GPS receiver and thus can act as your GPS navigator as well with SD card for data.
It uses a 4.2" sunlight viewable, wide screen, wide viewing angle, high resolution LCD. The unit is easy to mount in a standard 3.5" instrument hole with a very low mounting depth requirement and no need for brackets. While the instrument is wider than a normal 3.1/8" instrument, offset location of the rear part allows several options to install as replacement/addition in standard 6-pack panels.
As super low cost solution for VFR applications it can be used without AHRS.
We don't have the final prices yet - but you can be sure that it will be XTremly competitive with the lowest cost competitor out there.
Rainier
CEO MGL Avionics
Rainier
CEO MGL Avionics
