new VANS tail wheel doesn't fit the Aviation Tech fork
AirMarty
Member
My original (~20-year old) Vans tail wheel is getting worn and went to replace it. I had upgraded my RV-7 tail fork to the Aviation Tech (similar to Bell model) and the old tire fit just fine. The new tire bushing support is wider and metal rubs on the fork. Van Tech support suggested adding washers but that would put pressure on the fork base. Has anyone else had (and overcome) this problem before I order various tires to see what fits?
What is a Aviation Tech fork? Do you mean API or “Homebuilders Tailwheel” sold by spruce?
new Vans tail wheel doesn't fit Aviation Tech tail fork
The Aviation Tech tail fork looks similar to the Homebuilt Tail Fork but isn't chrome. See photo.. Seems the newer wheels are wider and the bearing race support rubs against the fork tines.
