So my left mag was getting high time, replaced it with a Surefly EIS. Install went fine and it started up on one revolution. After a couple of test flights the mag check got rough.
Once engine got nice and warm it improved enough to do another test flight. Decided to double check the timing at fixed 25 degrees BTC and found it was off by a bit. Now it's running much better.
But it seems like my EGT's run higher than before with the standard Slick mag. Anybody else seen this? BTW: Installed new plugs and harness and replaced intake gaskets and the rubber conecting tubes. This is on a Titan 0-360 with ECI cylinders, 550 total hours.
Pat
RV7 KHAF
Pat
RV7 KHAF
