This morning I re-read this thread: http://www.vansairforce.com/community/showthread.php?t=62738. In this thread the topic jumps back and forth between the location of the physical serial port connector, and Dynon software versions.
I am starting this thread to address the location issue only. From what I gather, the location of the serial bus connector was changed from the tunnel to up in the instrument compartment in back of the Dynon 180, in order to solve a noise transfer into the headset circuit. Since my kit was early enough to have the connector in the tunnel, I would like to change this before first flight, while the plane is still in the shop and easily accessed.
It seems all I would need to do this is to know which wires coming out of the back of the Dynon are the data wires, and clip them and install a new connector. Doesn't seem that would cause a certification problem, since it would be merely updating to the new design.
Has anyone else done this, or contacted Van's about it? Anyone have the pin-outs for the data wires?
Stein, care to weigh in on this?
My configuration: Dynon 180, no Dynon 100, autopilot, software version 5.4.
