Hi.
I am enjoying flying my RV9A but I would like to build something more nervous. So after a few days, I am almost persuaded to build an RV7.
My aim is to build:
- an aerobatic airplane;
- a metal airplane, since I got proficient on metal work;
- a plane which can run mogas or automotive gas, because paying Euro 2,70 for a litre is becoming too much;
- a taildragger, since it is safer when operated on grass and rough strips.
So, I think that the 7 will match those required aims. The last aim is to mount the most powerful engine allowed. I noticed that the 180HPs O-360 and IO-360 may run on MOGAS. But I would like to go with a more powerful engine. I believe that the 390 is not approved to use Mogas. I think that the Aerosport Power 195HP 375 can fit my needs. But I understand that this is a mod and so to be honest also such engine is not formally approved to use Mogas.
Two questions before start:
1) Which engine do you suggest? Is there a 190+ HP engine with enough low compression ratio approved for mogas use?
2) Since I would like to go with a slow build fuselage and quickbuild wings, would it be possible to order the fuselage first and after having completed it order the QB wings? I wrote to Van's but I didn't fully understand their answer: they told me that the SB fuselage comes with a few more parts wich normally will be included in the wing kit. But how can they match the center section with the main wing longeron, if the center section is at my home? Maybe there is no restriction on having spars matched. But I remember when I started my 9A that on the order forms something as "ship back the fuselage center section when ordering the QB wing" advice was written...
Thanks.
Camillo
My aim is to build:
Thanks.
Camillo
