N941WR
Legacy Member
I did not like the way the bracket for the Dynon expansion units require three rivets to hold it in place so I designed something a little different.
Check out these pictures:
Drawing
Back of bracket (Test fit)
Installed AP74
The platenut is for a 6-32 screw and I have been told that the location of the retention screw on the AP76 is different than the AP74/HS34. Just keep this in mind, should you fabricate one of these brackets.
Note: The AP74 pictured above was a dummy unit provided for test fitting purposes only. The production unit will have side plates and will be available labeled for either vertical or horizontal mounting.
Bill
(Pictures and comments released with permission from Dynon. Do not ask me any questions regarding the Dynon autopilot as I am not at liberty to provide any information. For more information, see the Dynon support forum.)
![](/proxy.php?image=http%3A%2F%2Fwww.repucci.com%2Fbill%2Fpanel%2FAP74%2520bracket%2520v2_small.jpg&hash=95474eaa91107e76a11518fba7d961b9)
![](/proxy.php?image=http%3A%2F%2Fwww.repucci.com%2Fbill%2Fpanel%2FAP74%2520alum%2520bracket%25202_small.jpg&hash=8712565260c05a7a460842df84b46e81)
![](/proxy.php?image=http%3A%2F%2Fwww.repucci.com%2Fbill%2Fpanel%2Fap74%2520dummy%2520installed_small.jpg&hash=5fa13487ba1410db4d61cf9b114eabeb)
Bill
