New Nuts?
doctornigel
Active Member
I've just removed my HS and my elevators for the n-th time. When it comes to the "final" install, should I use new nuts? The real question is, does the whitish nylon insert wear and lose some ability to prevent backing out at a future date? I do plan on painting a little mark (special paint) on the nut as a quick check for movement. Thanks!
It's the only thing that keeps you flying level! Your choice! I bought new ones.
.....but use castellated nuts or store bought cheapies for fitments then use new nylocs for final installation.
Hate to be a party pooper, but I would not have store bought cheapies in the place. You will only forget one once..................
Use the Nyloc, and if its only on and off once fine, if its getting a bit sad install a new one.
They are a lot cheaper than the alternative!
DB:)
