I'd sure be more comfortable with a Continental, over a Rotax. I'm even qualified to change my own oil in an O200. Wow! No gear box to overhaul every 600 hours, if it makes it that long. No dual carburetors to try to sync. No liquid coolant. No need to have the idle set at 1800 RPM, nor to crank the R's up over 5000 to get some horse power. Lot's of low end torque. Lot's less hoses and rubber stuff that deteriorates and Must be replaced every 5 years. And, a 2000 hour TBO to boot. And yes, it's a few bucks more. But, you get what you pay for.m Oh. did I mention that you can through all of the electrical stuff out, including the alternator and it will still start, and run, as long as you have gas, thanks to good old reliable mags.
It sure would be nice!!
Tom
If you want the O-200 LSA engine, then I'd say go with it. It's a time proven engine and it's well understood.
The 912 isn't perfect - far from it - but it's not bad to live with and it well suited to the LSA definition. It's just
different.
Some of my thoughts about the 912:
* Engine TBO is 1500 hr. Engines that run on mogas tend to make or exceed the TBO.
* Gearbox inspection interval is 600 or 800hr; overhaul is on condition. Again, engines that get fed mogas do better as lead from 100LL will accumulate in the gearbox.
* Oil changes are easy: Drain tank, replace plug, change filter, fill tank with oil, start and check for leaks and proper oil level. Very much like oil changes in a car.
* Liquid cooling makes it less sensitive to shock cooling and overheating on the ground at idle.
* Setting idle at 1800 RPM and syncing the carbs isn't hard - you rarely have to sync the carbs, most offten it's check and make sure they're balanced.
* Getting 5000 RPM is pretty easy - just open the throttle! The engine is quiet at WOT due to the standard muffler and low prop speeds (2200 RPM at engine redline).
* No mixture to adjust, which is helpful when taking off at high DA - no leaning to get peak Hp.
* Changing coolant lines at 5 years isn't difficult or expensive.
The 912 is a good engine - not perfect, but good. The TCM O-200 and Lyc O-233 are good engines that take well proven designs and make them better suited for LSA. I think they are viable alternatives to the 912S, but with the 1320lb MGTW limit on LSA, every pound counts, and the 912 is certainly lighter.
TODR
