Hi Gang,
I just received my Empennage kit yesterday and already I have a question.
Today I was going to trim the flanges on the HS-702 Spar Channels so that I could make the 6 degree bend but I'm just not understanding the instructions. I've been looking at the drawing and re-reading the manual for the last hour and I think I have an idea of what I'm supposed to do but I'm not sure of a couple of things.
First, the construction manual states that a #30 relief hole is to be made "centered on the bend radius of the flange". If I'm understanding that correctly, I would not hold the drill bit perpendicular to the spar web, nor would I hold the bit perpendicular to the spar flange. Instead, I should hold the bit at a 45deg angle. Is that right?
Next, the manual states that "it is not critical that the edge of the tab of HS-702 extends to the very vertex of HS-710 and HS-714. I guess I should not have thrown away my geometry book after high school but what the heck is a vertex?
Any guidance or pictures would be greatly appreciated!
Thanks........
Scott
Thanks........
Scott
