Cooling Shroud
I received my engine kit about 6 weeks ago and the shroud was not modified, or at least did not appear so. The LR mount attach bolt still unaccessible without modifying shroud as per the service bulletin. So, I will modify the shroud as per Van's direction. I've cut the hole but need to exceed the 1" specified by Van's because allen wrench won't fit with only an inch.
