Your SkyView 9 pin network cable has two communication networks, each using two wires. The SkyView compares the two network as being operational, and in agreement. This error message tends to mean:
- A 9 pin connector is not fully seated.
- A pin may have been push back.
- A wire was cut.
Go through and unplug the replug components until you find the problem.
Carl
