On the RV-8, I have Van's standard manifold pressure hose (VA-119) running from the number 3 cylinder to a nipple on the firewall (and then to the GRT manifold pressure sensor back behind the panel). I am going to be installing P-Mags to replace my aging Slicks, and need to "T" off the manifold pressure to the P-Mags. On our -3, I simply ran the manifold pressure to one leg of the transducer manifold (and used that to add a port for the P-Mags), but on the -8, the manifold is way over on the wrong side of the firwewall to make it convenient. So....anyone got an idea of a clean building-up of fittings to make this work? I can always make two hoses slightly shorter than the total length of the VA-119, and put a T-in the middle...but then I have to get some new hose ends, hose, etc....
Paul
Paul
