alpinelakespilot2000
How do you charge a Dynon (d180) internal battery while in the build process? Just turn the master switch on? Do you need to also turn on the Dynon while it's charging or will the internal battery charge while the unit is off? Is having a charger on my Odyssey battery a good thing to do while the master switch is on charging the Dynon?
Thanks.
Thanks.
