I am not the builder. The connection to one of the static ports fell off. The line appears to be 1/8" OD, coupled (heat shrunk?) to the more standard 1/4" OD line. I don't think the fitting is the Van's standard part, because it does not appear to be barbed. Images of both the disconnected line (in the empanage) and the exterior port are below.
Does anyone know what this setup is? I'm debating fixing it or just installing the Vans static ports and running "normal" plumbing. Either way, I will be fixing the fact that the static line doesn't go "up" before going down.
![IMG-2107.jpg](/proxy.php?image=https%3A%2F%2Fi.ibb.co%2FGVPnBP6%2FIMG-2107.jpg&hash=e34050072b6cf4a866d52968a038c802)
![IMG-2109.jpg](/proxy.php?image=https%3A%2F%2Fi.ibb.co%2FLh4qZm3%2FIMG-2109.jpg&hash=dcb64284aabc4b2395590b586f872510)
