Hello,
Am working on avionics and need to run RF cables from forward of the main spar to the aft fuselage but don't have any more room in the holes and grommets indicated on the plans of my RV9A. Also, I need to run the air speed pitot tube from behind the main spar, as it enters from the wing, to forward of the panel. Again no more room in the access holes.
Vans indicated that maybe it's possible to mount the antenna for the VHF, NAV and Trig under the fuselage forward of the main spar. They don't have any engineering to support any holes for conduit other than what is designed.
Would appreciate any ideas or experience in these areas.
Gary
Gary
