Don Patrick
I recently hung the engine and noticed that the oil pressure fitting over the right mag was touching the engine mount.
I'll have to remove the engine from the mount and find a new location for the oil pressure fitting.
There is a location above the oil cooler return line fitting that previously had a fitting on it...it's plugged now. Would that be a suitable spot for the oil pressure fitting?
Problem location.
Proposed location above the oil cooler return line.
Don
Problem location.
Don
