Has anyone made a bitmap scan of RV-12 Drawing 1 at a large scale? (This is the plan and elevation drawing of the entire aircraft at 1/16 scale.) Since it shows every seam and rivet, I thought it would be great to use as a layer in a paint program, then use other layers to try alternative designs to a pretty good accuracy.
I've done this with good results using a much smaller drawing in one of the pdf files from Vans - my scanner is too small for this large one though.
Thanks - Bill H.
Finished the tail, wings and fuselage kits arrive Friday!
Thanks - Bill H.
