Secured in three locations, these photos illustrates how I installed the ELT antenna in my -6A:Would someone happen to have any pictures of the installation of their ELT antenna under the Emp Fairing?
Not really. I am more concerned about the record of ELT effectiveness (or lack of it) in real world operations. Certainly, this installation would not be approved in certificated airplanes. Still, a periodic functional ELT test seems to indicate it works okay.Rick,
Are you concerned about antenna effectiveness? It does not seem to have a ground plane since the antenna is not mounted directly to the airframe.
John
I am not sure it's a good idea to mount the antenna internally. I certainly would like to avoid the parasitic drag and appearance penalty, but I also want it to work if I need it. How are others viewing this?
Someone will be sure to correct me if I'm wrong but I've been told Van's has been known to mount an ELT antenna under the empennage fairing.I am not sure it's a good idea to mount the antenna internally. I certainly would like to avoid the parasitic drag and appearance penalty, but I also want it to work if I need it. How are others viewing this?
