freegespeed
Active Member
I thought I'd check the VAF brain trust for some advice about my dumb hanger rash episode on the rudder of my RV6A.
I was in the middle of my nose gear AD job when my expansion bolt floor anchor pulled out that was holding the tail down while the gear leg was being sent to Langair. Luckily I had some padding under the engine and also that my prop was turned parallel to the ground. But the tail swung up and banged into the roof of the hanger.
To get to the point I have pretty bent up rudder which doesn't look salvagable after it hit the roof of my hanger.
The vertical stabilizor is good except for some fiberglass cracking in one spot.
I'm not the builder but I have done extensive work on my plane over the last four years.
I have a couple of questions.
First, does anyone know if Vans sells the necessary replacement parts for the older (1993) RV6 rudders? I have all the plans to my plane.
Also is there anyone who builds replacement rudders for an RV6?
Any help would be appreciated.
