need instructions for cabin heat box installation
IowaRV9Dreamer
Does anyone have a copy of the TG-10 heat box installation instructions? I'm installing a stainless copy of this box and I'd love to see how Vans recommends to do it.
It appears that both mounting points will be in "open" area of the firewall. I was planning on putting platenuts on the heat box and then using AN3 bolts (or maybe #10 washerhead screws?) with washers from the inside.
If you have a scan of the instructions, please email or PM me.
Thanks for any help,
I have the stainless version too ....
And got NO instructions of any kind with it. I did exactly as you indicate: #10 platenuts on the heater box with AN3 hex bolts from the aft side of the f'wall. worked like a charm. I'm debating between high-temp RTV and proseal under it when I final bolt it in place.
