Jeff R
I am back working on the HS. In clecoing the right half of the HS, we are to include a shim, the HS-909, between the forward spar, HS-902, and the inner rib, HS-904. Well, the holes all line up much better if I omit the shim. With the shim in place, the holes don't quite line up. The rear spar assembly fits perfectly, so am thinking of doing away with the shim.
Any of you have any issues here?
Sorry for all of these questions!
Jeff
Jeff
