I tried mounting the TT pitch servo to the bracket that I installed during original construction. By everything that I can tell it is right where the instructions call for however I would have to cut the servo arm down to the closest hole to keep the elevator push tube from hitting it when in the full nose up position. This would also require cutting the connecting rod which might not allow enough travel.
Lucas said he has not run into this before. He sent pictures of an installation but I don't see anything unusual. This is not the first TT system that I have installed but it is my first in a 7. Have any of you run into this before?
