Need help with tip up canopy restraint
Larry DeCamp
Friend
I am ready to fab the linkage that holds the canopy open. Obviously a string that will break for a jettison option is the simplest. Gas struts are cool , and would consider that if someone can suggest the layout and strut specs. However, the folding metal linkage I recall in pics seems robust, light, simple with no preload on the components. So does anybody have some solutions to share for the RV4 tip up ? Pics would be very helpful :)
Larry,
I have what you're looking for in my 1994 RV-4. It's been working great for 26 years now. Sadly, I couldn't find a photo.
If you send me your email or phone number, I'll send you a pic and some dimensions. [email protected]
This is what I'm using copied from a fellow RV-4 who copied it from someone else. Simple,works great, light and cheap. Lowes or Home Depot cabinet department.
<a href='https://postimg.cc/G8zHX75L' target='_blank'><img src='https://i.postimg.cc/sxC7DbPh/IMG-0121.jpg' border='0' alt='IMG-0121'/></a><br /><a href='https://postimages.org/'>best image hosting</a><br />
Skip
NC
I built this when I was barely 30.... seems like an eternity ago.
When the canopy closes, the bar virtually disappears in line with the rollbar.
RV4 canopy
Great idea, gettin started on a 4 project when Vans starts shipping parts, question, does it require a nudge to collapse when closing the canopy, or just move on its own.
Chris Santschi
RV4 starting
RV8 - sold a while back..
Chris,
Maybe I got lucky, but it requires a small nudge, which means that it has been remarkably resistant to blowing shut inadvertently. Nonetheless, I don't leave it open if it's windy.
I used a very similar set up on my Rocket with similar good results, and plan to do the same on the next one.
