Loydtiger1
I'm New Here
I am in the process of wiring the instrument panel in my 8. I am installing a D-180 flight display with a Garmin 340 audio panel, GNS430, Icom IC-A210 and a GTX327 transponder. All was going as advertised until I started installation of the IC-A210. The installation instructions look like something you would use to install your new VCR. Instructions for this radio as a stand alone com are clear enough but I need to connect the A210 to the 340 audio panel. Instructions for this are very vague at best. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Has anyone installed an Icom IC-A210 connected to a Garmin GMA340? If so I would really appreciate help with the pin connections.
Loydtiger1
Loydtiger1
