430 TX and RX data
So, it sounds like I can split the TX from the 430 provided that each device it goes to Be on the same baud rate and format.
Spoke with Uavionx and they stated just a TX line from the 430 was required, no TX back to the 430 was needed, as the AV30 does not provide any info to the 430 GPS.
The JPI 830 seems to be a bit different requiring both TX and RX from the 430 to the JPI 830. Looks like I can split the single TX from the Garmin 430 providing both the AV-30 and the JPI 830 require same baud rate and format. Just one line back to the 430 from the JPI 830 EDM.
**** at tis point I might as well just plumb the Garmin 430 with 4 circuits, TX and RX form 2 channels.
If some has a better solution I am open to all comments and suggestions.
