I bought some already built RV-10 wings (slow build) a couple of years ago and was told the tanks passed a pressure test prior to placement into the wings. Now that I am ready for them, I repeated the pressure test and one tank failed with a leak along a lower seam inboard which I sealed but a retest failed again!
Now I am faced with having to remove the tank from the wing to find and seal the leak (leaks)! I have no build instructions for the wing and could really use a set if any one would care to let me borrow or buy one. There are a dozen or so bolts with nuts exposed in the two inspection holes and through the inboard rib, but I tried to loosen one and the bolt turned with the nut and there is no way to get to the other side! I thought that I'd better ask for help before I mess up things more than they are already! Would appreciate any help! - Thanks, - harrydga
