Well, I didn't like the look of the bent down tabs. So I cut them off and made riblets, I did the same for the bends on the elevator as well.
The problem came - when I cut the tabs off, I cut too much - you have to leave well past the relief notches in order for the inboard edge of the trim tab to line up with the inboard edge of the elevator, and the the attach point for the trim motor to line up with the notch in the elevator, and lastly so that there is not a huge gap between the outboard edge of the tab and the elevator. Hope you see what I am talking about, I don't have pictures of my mistakes. The first tab violated all three, it wasn't a deal killer structurally, but it just didn't look good enough for my taste, so I built another. It took a few tries to get the riblets right, and I even made a new spar when I over countersunk the first. I have a 4' bending brake, so it's not difficult to re-fabricate my screw ups, fortunately.
Even after doing all that, after riveting the tab together - except for the leading edge with the hinge - I could see the tab was twisted by sighting down the trailing edge of the tab while holding it in place to the elevator. So check for that before you rivet the hinge to the leading edge of the tab. Actually, check for it before you rivet the tab together!
I untwisted and re-clamped the leading edge and hinge, and riveted it, starting at one end and moving one rivet at a time to the next, checking after each rivet to make sure the twist was still gone. Because of the way the spar and the skin and the riblets fit together, in order to get rid of the twist I ended up with the hinge having a very slight bend in it, but not enough to bind in the small amount of travel the trim motor gives it. If you can build the tab without a twist, you will be ahead of me.
All my trailing edges ended up really straight with both elevator counterweights even with the HS, so no twist there, thank goodness. However, my rod end bearings are one half turn past the maximum 7/8" for the right elevator to not rub on the HS rear spar, and even there the inboard part of the HS skin is rubbing on the elevator at 28 degrees up, so I have some issues there still. Calling Van's today.
