I'm trying to set up a mock panel area up for my panel upgrade. I'm trying to find where best to locate components on the main panel, sub panel, support structure etc. I'm doing this to help minimize the downtime for my flying plane and to hopefully work out any interference problems that might pop up. I have a full size main panel drawing but need some others. This is for a RV9 with a sliding canopy. As I understand it RV 7 components are the same. What I need is as follows:
F 7107 R & L
F 7108 A
F 7105 A
F 7105 B R & L
F 7103
Full scale outline drawings of these components would work best or at least dimensioned drawings. On the 7105's there appears to be a bend about 1/3 of the way up from the bottom. a dimension for the bend and an estimate of the angle would be helpful.
Thank you for any help you can provide.
F 7107 R & L
F 7108 A
F 7105 A
F 7105 B R & L
F 7103
