I have a SL-30 with a GRT HX and Trutrac autopilot and have just started to play with navigating with the VOR. I tuned in a VOR and adjusted the right knob(proper name here?) on the GRT to a radial I wanted to get on. I was on the proper Nav 2 mode, and ENAV. The plane did not really make an attempt to intercept the radial I had set, instead it pretty much flew to the VOR and THEN tracked the radial outbound.
So, how do I get it to intercept a chosen radial and track to the station? And how does it determine where, or the angle of intercept? If you are far away it could get ugly.
